WD spin out wheels |
one54dodgetruck ![]() Silver Level ![]() ![]() Joined: 25 Jul 2011 Location: Chehalis, wa Points: 399 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jul 2011 at 11:27pm |
Ok so what has worked to free up the locks? I just broke 2 3/4" impact sockets. Next Im thinking im going to have to take the wheel off so i can get more heat to it. Whats your thoughts?
Thanks
Andrew
2 WDs
B B112 D14 D15 shuttle 180 185 7040 Hd7w D14 D15 185 7040 pd |
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1787 |
I know it's a crapshoot but I use equal parts acetone,turpentine,automatic tranmission fluid,and kerosene in a pump oiler and soak every unit. then BUMP each unit with a impact and resoak. I did this for a couple of days and they come loose rather easily. Lucky I guess but who knows? I got this penetrating oil recipe from a career locksmith. Good Luck!
Chris (swIA) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Prescott, IA Points: 319 |
Unbolt the wheel from the hub and then put the locks in a vise remove the snapring and drive it out. The clean them up with a wire brush and reassemble using antiseize. Much faster and easier in the long run.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Lay the wheel on the ground take out the 8 bolts that hold the locks to the center and beet the wheel center out. than you can take apart the locks clean and put back toghther with never seize. it took me a day to do one tractor. I fought with the other tractor before this for a couple days trying to break them free. managed to break one lock and one 3/4" drive socket. after moveing the wheels on that one a year later they would not move again. The ones I dissambled still work great
Ray ![]() Orange Level ![]() Joined: 21 Sep 2009 Points: 1979 |
I have good ones that work good. $10.00 each. 785-353-2392
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7513 |
Unbolt them from the wheel center and separate the rim and wheel centre, then you will be able to access all the places where rust sets in. They will free up with lots of heat. In the wintertime, I had all the ones from my D14 and 15 off to free up. I let them cook in the wood burning stove for a day. They came apart real easy after that! Sanblasted and primed them afterwards to keep the rust off. |
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Link to a previous post on this subject. Good luck; remember that persistance and perserverance could prevent damage due to brute force when freeing up the eccenctrics.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
ChuckLuedtkeSEWI ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
If you're going to try to loosen them up while keeping them on the tractor, put the one you're working on at the very top, that way the weight of the tractor will not be on it while you're trying to free it up. I have taken them off and put them in the electrolysis tank to clean them all up. then once all the rust is off, you can take them apart easily, antiseize and paint them back up. The only bad thing is you will lose all of the paint that is on them. |
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
