WD Shooting Flames at High Idle
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 4:15pm
The jackleg way I do it is to take the valve cover off and turn the engine until #1 valve
closes and then turn the rotor until you're at Number #1 on the cap,won't be perfect but will give you a pretty good starting point.
KD8NGV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 10:27pm
So I went out and took apart the Distributor.  Here is what I found.  Is this my problem?  What is the next step?  THANK YOU for ALL of you HELP!!!  I really appreciate it!
Go to this link for the pictures: https://1drv.ms/f/s!Auo4c4_wWK4MiKdyKyq_v6GlGrwSEA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 5:53am
Ahhhhhhh! I believe that your distributor is junk! I have never seen one that bad! Check with some of the use parts guys and get a good working one. Or call Steve at B&B and get a rebuilt one. Are you sure this was in the tractor that was running at all? That's why its always a good idea to take some pictures.
Ok someone might be able to bring this back to spec but I seriously doubt it! Just my opinion.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 6:59am
Nasty!!! Time for a replacement. I'm with Chris and surprised it ever ran. Bet it will run much better after it's replaced!
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:17am
I had it running when I bought it at the auction and drove it a while.  It must have just rusted shut the year it was sitting (inside) and put the final nail in the coffin.  I assume that I just take the top 'mushroom' (picture 2-4) part off and leave the part attached to the governor on? When I get a replacement (maybe at Rochester GOTO) how do I mesh it correctly with the gear on the tractor?  (Part in Picture 1)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 2:49pm
When you are ready to install the new or rebuilt distributor, crank the engine by hand so number 1 cylinder is on the compression stroke. ( with all plugs out, put your thumb over #1 hole and feel for compression as it is turned.) Bring that piston to TDC, you can feel the piston with a wire thru the plug hole, or get the Center(NOT the fire mark) mark on the flywheel in the middle of the hole.
 Turn the distributor so the rotor points to the area in the cap you will use as #1 wire and install it. Now turn the distributor so the points just start to open and snug it down. Install wires in firing order clockwise (looking down) around the distrib and put them on the right plug.
