WD Shifter Tower
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Topic: WD Shifter Tower
    Posted: 21 Aug 2011 at 1:19pm
Can the cone that the shifter ball sits in be replaced?
If it does, who has it? I looked on the Agco parts site awhile back and couldn't find it seperately or a part#.
The shifter will fall in if I don't hold my mouth just right while shifting. Another problem?
TimOk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimOk Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 5:41pm
Fixxer. Sounds look your shifter is worn at the trans end. Use the search at the top of the page .Type in  Worn wd shifter, and it'll take you to posts that show you how to build up your shifter end. Or do as I did ,go to Agco allis dealer and order a new shifter. Its after market but it works well. $125. or so. Hope this helps    Tim from southern OK
Tim from the Rocking TJC
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 6:02pm
  we have a new shift tower   nos    1-574-342-4545
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 6:05pm
Don't forget to replace the slide block(s)
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 6:03am
It is a new shifter with a new slide block.
So I'm guessing I need another shift tower.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 8:58am
Wow, never heard of a shift tower wearing so badly that it would allow the shifter to
slip down inside of it!
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 9:12am
The shift tower is almost always the main reason for the problem. common thoght always is that the lever is the problem but the cup in the shift tower always gets worn so far down that the geometry changes to the point that the shift lever can come right out the front of the slots in the shift rails. This along with a worn lever only makes the problem worse. So as a very good start I would get that NOS shift tower from Norm and go from there
This page was generated in 0.089 seconds.
