WD Shifter Help
THarper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THarper Quote  Post ReplyReply Direct Link To This Post Topic: WD Shifter Help
    Posted: 03 Nov 2025 at 5:39pm
Hello,
My WD's shifter was sloppy in the shift tower and would spin all the way around, making it difficult to find some of the gears. Thanks to the forums and internet I was able to re-weld up some material on the shift ball and then cut a new channel, plus I added a pin and channel on the other side of the ball. The shifter works very nice now, however I don't understand the special washer that sits between the shift ball and snap ring. Mine didn-t have either when I went to take it apart. The washer seems to be to big to go down into the top of the shift tower. Anyone experienced this issue before?20251104_090951.jpg
Edited by THarper - Yesterday at 9:18am
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:16pm
Wow, that's weird, usually I think that piece and the weird snap ring looking thing both go down in there and sit on top of the "ball" in the shifter... Can't dig up a handy picture at the moment though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote THarper Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:13pm
I thought it seemed weird also. I assumed it should not have to be driven down in, but wasn't sure if they usually just drop down in the tower and sit against the ball or have some resistance going in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 5 minutes ago at 4:28pm
It doesn't seem like you have the correct parts for that model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 47 minutes ago at 4:46pm
From parts book...#9 ring 70202875...#12 washer.70207772 I've never consulted Brenda @ Sandy Lake but everyone says she knows parts. Suggest you contact her for correct pieces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote THarper Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 11 minutes ago at 8:22pm
I will look into that for sure. Thank you all for your help! Much appreciated!
