WD shifter bushings |
jhendy18 ![]() Bronze Level ![]() Joined: 09 Sep 2020 Location: central MN Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Sep 2020 at 2:15pm |
Hey everyone,
I am working on a WD and noticed I have 1 shifter bushing that needs replacing in the hand clutch assembly. Does anyone know where I can source one of these? thanks
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8535 |
Jhendy18,
Welcome! Can you better describe the bushing you need? Lots of parts in there.
Regards, Chris |
They never had a bushing, but you can replace the pin, bore lever and install a bushing. McMaster-Car would have a bushing. MACK
Hey Chris,
They are inside of the clutch shifter assembly, where it slides over the transmission shaft. I attempted to upload a picture here let me know if you can see it, if not I'll try to upload one from a computer tomorrow. 20200909_210033_2020-09-09_21-02-57.jpg |
Item #4 in the parts diagram I posted
Ok I see the bushings but for the life of me I do not remember checking mine for wear or replacement?
Call Sandy Lake or one of the other suppliers that sponsors this site. Regards, Chris
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
Now Mack, be careful. See the posted picture for the 'wanted' bushings. Bottom left corner, 2 bushings in Hand Lever, P/N 224705. Item 1 on page 222 G |
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2037 |
I have lots of used hand clutch parts on the shelf if you think that would work for you.
Thanks for leads everyone!
I called sandy lake and the part is no longer made, however according to the parts book if you order the shifter assy these bushings should be included in it. I ended up buying a used shifter assembly off of ebay for half the price that has at least 1 good bushing which is all I need.
