WD Shifter again
Tim in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Topic: WD Shifter again
    Posted: 17 Sep 2011 at 11:28pm
 Guys, please excuse my ignorance on this matter, but this is the first time I've worked on the WD shifter problem.  I have some more questions.
In the parts and service manuals they show only one snap ring to hold the shift lever into the shifter tower, mine had two snap rings, and the shifter was still loose, can I assume that the tower is worn beyond use?
When installing the shift rod into the tower, I assume all the lugs on the shifter forks should be lined up, and the trans gears in line with the shifter forks, then install the top back on the trans?  Or do I have the sequence wrong?
I have to order a new shifter washer and snap ring, maybe a shifter tower, should I also get a new over sized pivot pin and file to fit, the old one fits fine.
Any and all help will be greatly appriciated.  Thanks, Tim.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2011 at 7:54am
all three rails in center condition, then install shift handle washer then snap ring, may require 2nd snap ring to take up play.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2011 at 8:12am
It is easer to put top on first then install gear shift.  MACK
