WD serial number |
Post Reply |
WDmatt
Bronze Level Joined: 22 May 2020 Location: South Dakota Points: 8 |
Posted: 23 May 2020 at 4:34pm |
I just bought a WD, and the serial number is 209286. I know I'm not reading it wrong, and the serial numbers ended at 131,273 in 1953. I'm almost 100% positive that the tractor is a WD, not a WD-45. How is my serial number possible?
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5370 |
It would seem that someone replaced the complete 'rear end assembly' with one from a WD-45. Does it have a Curved Shifter ? BTW where are you getting the Serial No. from on the tractor ? Edited by Gary - 23 May 2020 at 6:12pm |
MACK
That # is a parts #.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2316 |
Serial # is located on left rear housing and is stamped in not cast in.---look again at your tractor!
WDmatt
Yeah, it's stamped in, I just miswrote cast on my post. It does have a curved shifter
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5751 |
Matt... your engine... look at both sides of the block. Are both sides smooth, or does ONE side of the block have a large metal plate with lots of bolts holding it on?
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8276 |
I did not do the research to be able to help you with the serial number. But I will throw this in the mix. We have a WD that had the rear end changed and does not have the original number on the back. I am still kicking myself for not getting the original serial number off the casting we scraped!
Regards, Chris
Edited by Sugarmaker - 25 May 2020 at 9:35pm |
WDmatt
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1289 |
That would be a 1955 WD45 if all else is in agreement.
Orange Level Access Joined: 12 Sep 2009 Points: 20472 |
Engine serial number is behind the carb/air cleaner hose and would read 45-XXXXXX-G. If it is a WD engine it would read W-XXXXXX-G or P. If there is no serial number, the block has been replaced one time in the past and no one ever stamped a s/n in it.
ac fleet
one of my 45's came up as a 55 and the parts frame tractor came up a 56.
Post Reply | |
