WD Serial Number Location
cdweirrick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdweirrick Quote  Post ReplyReply Direct Link To This Post Topic: WD Serial Number Location
    Posted: 23 Apr 2016 at 4:35pm
I have been trying to find where the serial number is located on my WD. I am total newbie when it comes to anything about this machine. I looked under the differential housing and found this number 200921. Not sure if it means anything other than a part number. Help Please! :)
Grandpa's 1950 WD
1950 G
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2016 at 6:31pm
Its directly to the left of differential cover just below left brake cover
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2016 at 7:17pm
Yep grinder220 has got the right spot. It will say wd then your # .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2016 at 7:21pm
That number would be to a WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2016 at 8:40pm
Early WD had the tractor number stamped on the top of the housing to the right side of the left brake cover.
 http://wsmth.people.clemson.edu/images/SNWD452.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdweirrick Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2016 at 9:10pm
Thanks guys! Serial Number WD45089.
Grandpa's 1950 WD
1950 G
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 9:30am
1950 WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 9:33am
"I looked under the differential housing and found this number 200921"
That would NOT be the tractor number.Probably a casting number
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdweirrick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2016 at 7:37am
Thanks for all your help. Grandpa had this tractor my entire life. So may great memories are surrounding that tractor. I want to take great care of it so maybe someday may kids and grandkids can say the same thing about it.
Grandpa's 1950 WD
1950 G
