WD running rough, no power and killing
kofted View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kofted Quote  Post ReplyReply Direct Link To This Post Topic: WD running rough, no power and killing
    Posted: 03 Jun 2024 at 6:01pm
My WD started running rough, not having power and killing. I would appreciate any help. I need help on troubleshooting.
- Checked inside the tank: Clean
- Checked fuel flow from tank to bowl, bowl through line, and then cracked the drain on the carb. All is good
- removed the carb and took all apart, inspected and cleaned. Was not much to clean.
- Adjusted idle mixture screw to 1 1/2 turns out. Set load screw to approximately 1 1/2 turns out.
- Checked the plugs (running Campion J8C). All are black. Cleaned them all . Set them to .030" I turned it over with plugs out to check the spark and it looks good.
- Checked the points over. Some cloudy/discoloration on them. Polished them up, set them at .020"
- Took the valve cover off and cranked over. All valves seem to move as they should.
I have had this tractor for about 30 years and had very little problems with it. I keep it in a shed. It has the magneto. I run it about 50 hours a year with a back blade and a brush mower.
Edited by kofted - 04 Jun 2024 at 8:46am
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 6:37pm
Originally posted by kofted kofted wrote:
I have had this tractor for about 30 years and had very little problems with it. I keep it in a shed. It has the magneto...
It's probably time to have the magneto rebuilt and recharged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 9:02pm
you can randomly try a new coil and condenser to see it that helps.. I have done that a couple times with success... 6 months ago i bought a "reconditioned" unit off this site from one the "rebuilders" and it made a world of difference.... Getting a new coil / "GOOD" condenser and point and recharging the magnets and new parts for the impulse is a LOT more than i was doing... and it runs GREAT.
Edited by steve(ill) - 03 Jun 2024 at 9:02pm
