WD Rear Rims |
DanM71 ![]() Bronze Level ![]() ![]() Joined: 29 Aug 2025 Location: Missouri Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 12 hours 16 minutes ago at 12:46pm |
The spec sheest says to use 11x28 rear tires. What is on the tractor is 13x28 and the new tires I bought are 13.,something x 28. Now I see I need new rims and am seeing everythig from 9" to 12" wide. Should I go with the 12" wide or keep looking?
thanx, dan |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21939 |
An 11 x 28 tire is the same size as a newer 12.4 x 28. This is the OLD numbering system (pre 1958) and the new numbering system with a decimal point (1958 and newer). A 12 x 28 tire is the same size as a newer 13.6 x 28. A 13 x 28 tire is the same as the newer 14.9 x 28. I would use an 11 inch wide or 12 inch wide rim for any of these tire sizes.
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 461 |
Whoah, that's getting complicated! Or at least confusing. 🤔 . Edited by jvin248 - 4 hours 25 minutes ago at 8:37pm |
