WD rear rim size |
Souder01 ![]() Bronze Level ![]() Joined: 17 Aug 2019 Location: Indiana Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Sep 2019 at 1:12pm |
I am restoring my first WD and I need a new rear rim. I have found one locally for sale but I’m not sure if it’s the right size. My tire size is 13.6-28 on a 12-28 rim (that is what it says on the tire). Below are photos of the rim I am looking to buy. I think it’s a 11-28 but I’m not sure. Anyone know?
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
From your pictures that apeats to be a 10x28 rim.why dont you stick the tape between your rim and center and measure it. I think my WD 45 had 10x28 rims on it
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
From your measurement, from bead to bead it appears to be a 9" rim. Would probably work but you should measure the old rim or the rim on the other side and match it.
Thanks everyone for your help!
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
It sure does look like a 9" X 28"......seems unusual......the narrowest I've seen is 10".
I notice some very legible stamped letters and numbers right under your ruler......I bet you could clean them up real well and find the rim size printed there.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21955 |
10's, 11's and 12's on WD and WD45's. D-17's were mostly 13's with some late models maybe 15, but I've never seen one.
After looking closer, I'm inclined to believe this is a common 10" X 28" rim.
