WD rear hydraulic problem
G226WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Topic: WD rear hydraulic problem
    Posted: 01 Aug 2011 at 6:49pm
Im starting to notice something lately whenever i pull with the drawbar on the allis 3pt hitch if i pull hard the hydraulics always lifts high as it will go and sometimes it will stay up even when i move the left lever on the quadrant is all the way to the bottom.
i have to shut the tractor off sometimes to get it to go down.
i made a homemade box to carry my chains in on the 3pt hitch but the box keeps getting smashed. is there something wrong or is it a setting somewhere
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 6:59pm
Sounds like you need to set your hyd pump to the hold position.  Should be able to use the sticker on your battery box, or this picture.
AaronSEIA
