WD Radiator Shutters?
51ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Topic: WD Radiator Shutters?
    Posted: 10 May 2016 at 12:42am
My 51 WD Does not have the radiator shutters but it has the hole in the nose cone for the lever. Did all gas Wd's come with the shutters or was it just an option?
-Jesse
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 4:38am
Our 49 WD has the hole as well. And we have the shutter hanging on the wall. But I really can't answer your question.
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 7:19am
I believe the shutters were used prior to the tractors actually having thermostats in them. Once widespread use of thermostats was adopted, shutters were no longer necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 9:03am
Pretty sure all WD's had shutters and no thermostats unless the last ones used T-stats when they went to tall head.Dad put a 45 T-stat hsg on the WD.Required some "snakey" plumbing on bypass and a flex upper hose to reach radiator.Our shutters are upstairs in the shop.
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 10:14am
I have a 1951 WD, been in the family since new.  Has both shutters and the single exit water mainfold with thermostat in its housing.
Incidentally, the 1951 Operators Manual shows the earlier double exit water manifold complete with thermostat in its housing.
If anyone is really that interested, I can scan the page for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 1:02pm
1950 WD's both had shutters which are long gone. 1952 did not have them.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 10:24pm
left over nose cowls.....
This page was generated in 0.073 seconds.
