WD radiator mix
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Topic: WD radiator mix
    Posted: 13 Aug 2014 at 3:26pm
Tried the search but didn't find....Which of the 'modern' antifreeze products do you use in your WD... I am having a leak fixed in mine and wonder what's best and what % should be antifreeze... central Kansas so gets down to zero once in a while...Peace
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 3:43pm
mine sits in cold storage over the winter with 50/50 Prestone here in MN where it's been -30 or lower several times the last couple years, never had an issue
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 4:39pm
I found out years ago that some tap water will cause rust in the cooling system.
Ever since then, I buy one gallon of anti-freeze and one gallon of distilled water (or take it from my dehumidifier) and mix them 50/50.
Then, I always have antifreeze ready to use whenever i need it. No mess, no fuss!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 6:41pm
Thanks guys.... I know where the de-humidifier is...that will save me from looking for the distilled stuff, I will let the de-humidifier distill it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 7:07pm
dunno if it rains in kansas but rainwater is swell for radiators too Wink
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 7:34am
You can buy most antifreeze today already 50/50 mixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 8:39am
May give that a look too, thanks...although I have started getting water from the de-humidifier...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 8:39am
Yes you can...but...even when you add the cost of a gallon of distilled water, buying full strength and mixing it yourself is much cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 8:41am
Brian, I was thinking that might be the case...that is why I am waiting for the de-humidifier to do its' thing.
