WD Quit on Me
DanM71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanM71 Quote  Post ReplyReply Direct Link To This Post Topic: WD Quit on Me
    Posted: 3 hours 33 minutes ago at 8:48am
GM Folks,
     I am NOT a gearhead so be gentle. I was using my WD to plow some snow and everything was going great, for a while... While plowing uphill, it just shut off on me. Trying to restart, it turns over but will not fire. I checked gas in the tank and there is plenty. I took the fuel line loose frpom buth the tank and carb and fuel runs out of both. Can someone please point me in the right direction to diagnose further? I am kinda short of good tractor people here in the Ozarks.
Thanx,
dan
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 21 minutes ago at 9:00am
If it seemed like someone turned it off check the spark.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 17 minutes ago at 9:04am
Check power to distributor and coil. Take distributor cap off and check points to see if they are opening and closing as you turn over engine. Should be a .020 gap when they are fully open. Maybe clean the points with small file or some emery cloth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 17 minutes ago at 9:04am
yes... most common failure would be the coil or the condenser = no spark.
 this a distributor system ? .... is it 6v or 12v ? ... if 12v, is the coil an old 6v coil ?
Edited by steve(ill) - 3 hours 15 minutes ago at 9:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 51 minutes ago at 9:30am
And the ignition switch on my 49 WD (original) sometimes breaks contact and dies as if shut off....cause it is! You can pull a few wires off plugs and get cap off then remove rotor and plate over points. Put rotor back on and rotate engine to where when you twist rotor it opens closed points. At this point you pull coil wire out of cap and hold end close to block and twist rotor. You should have slight arcing at points and spark jumping to block with switch on. This is providing you have a distributor not a mag.
Edited by SteveM C/IL - 2 hours 42 minutes ago at 9:39am
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 42 minutes ago at 9:39am
Magneto or distributor?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 40 minutes ago at 9:41am
If no spark at coil run a jumper wire right from the battery to the coil. That will bypass the switch.
