wd question |
wildbill26
Joined: 25 Sep 2010 Location: claysville,PA Points: 534 |
Topic: wd questionPosted: 07 Aug 2011 at 7:56pm |
I was talking to a guy who swore he put a d17 crank, rods and pistons in a wd block is that possible? since the wd is a 4x4 bore and stoke and the d 17 is a 4x4.5 bore and stroke thanks
deereequipment1
Joined: 31 Mar 2011 Location: Southern MD Points: 261 |
Posted: 07 Aug 2011 at 7:59pm |
I think those parts might fit a WD45 engine (226 cu)....and that WD might have had a 45 engine put into it at some point in it's life.
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC, also own a D-10, D-12, G and a CA. |
wildbill26
Posted: 07 Aug 2011 at 8:08pm |
thats what I though but he swore it was a wd block, i have never had a wd engine apart so I didnt know but I realy didnt think it would fit, I bet your right though its a wd45 block
deereequipment1
Posted: 07 Aug 2011 at 8:14pm |
Not knowing for sure if you can mix and match the heads, but the WD45 engine (226cu) shoudl have a 4" tall head. The WD engine (201 cu) should have a 3" tall head.
Also, the WD engine, has a large metal plate mounted on the Right side of the engine, that takes up the whole length of the engine.
one confusing factor that I had experience with, is the Leroi 201 engine that doesn't have that plate, but comes in a 226 or a 201 configuration. the shorter head, and the plate over the right side of the engine, "should" tell you that it is a WD engine, not a WD45. |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Posted: 07 Aug 2011 at 8:15pm |
I'm pretty sure the D17 crank has different size main journals on the crank. That said, a WD45 crank is the same stroke as a D17 and will drop right in, along with any of the 226 engine kits. The kit in my WC is for a 170.
AaronSEIA
wildbill26
Posted: 07 Aug 2011 at 8:22pm |
thanks for the information guy I realy apricate it alot
Jim seIl
Joined: 17 Sep 2009 Location: Albion Illinois Points: 382 |
Posted: 07 Aug 2011 at 8:42pm |
will not work D-17 mains are bigger
CTuckerNWIL
Posted: 07 Aug 2011 at 10:00pm |
Everything will fit except the crank. You would need a WD45 crank to fit the WD block.
wildbill26
Posted: 08 Aug 2011 at 4:21pm |
ok thank you guys very much
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 08 Aug 2011 at 5:00pm |
Charlie wasn't the first 17's the same crank as the 45 or E motor. I thought the change in lower ends came later like Ser. 2 or so.
Brian Jasper co. Ia
Posted: 08 Aug 2011 at 5:11pm |
Is it the mains are different size or the thrust main is not in the same position? I was thinking this came up some time back and it was the thrust main was not in the same position.
Lester
Posted: 08 Aug 2011 at 5:52pm |
No D-17 had the smaller crank from the factory. The Nebraska tested the first D-17 in 1957 and it had the big crank witch has 3'' bearings. Although the first D-17s had the WD45 style lube system.
wildbill26
Posted: 08 Aug 2011 at 6:29pm |
i came up with another question now what about the rods are wd, wd45, d 17 all the same rods?or are they diffrent
Posted: 08 Aug 2011 at 9:13pm |
They will interchange but are not exactly the same. WC and WD rods have shims. WD45 and D17 have no shims. The newer the rod the stronger it is. Many different forging numbers over the years and I imagine the weight increased a bit as well.
