WD pump adjustment
Tim in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in MN Quote  Post ReplyReply Direct Link To This Post Topic: WD pump adjustment
    Posted: 07 Feb 2012 at 10:56pm
How do you guys set the pump adjustment for running a remote cylinder on a WD ?  I've read the op manual 3 times and it doesn't mention a remote cylinder except for delayed lift.
Also, was there ever a stop of any kind on the lift lever for the WD series?
Thanks guys, Tim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 12:03am
Remote and lift arms all work off same oil so there is no special setting for remote. There is no stop on lever but when pump linkage is correct you will feel the hold position on the quadrent about half way down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 6:05am
If you have a standard remote connection, the remote works with the lift arms. If you have a transport valve on the remote connection it may need opened up. There is no pump adjustment for the remote cylinders except for the delayed lift for cultivating etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 7:03am
Adjust pump for "hold" position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 2:57pm
There was a "Stop" available for the hydralic quadrant to use when you were using mounted implements and the traction booster.  It clamped to the quadrant like a "C" clamp.  It's in the parts book, but I've never seen on in real life.
There was also a "Stop/depth control" system that stopped the lift arms from lowering beyond a set point.  This was for use with the rear scoop and blade to control depth of cut.  Never seen one of these either except in the parts book for the rear scoop.
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 3:13pm
Ted:  When I first started plowing with the 1950 WD Dad had with a sc full mounted 3 bottom plow, he would drive it a round and set the lever where it was for the TB and clamp one of these "C" clamps on the quadrant so I just dropped it down to the stop when i turned on the end and kept plowing.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 7:58pm
We have a stop for our quadrant. I'm thinking its dealer item. It has a thumb screw on the back and clamps on. Ryan
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 8:34pm
you are correct ryan,there was a stop you could buy for it.the part# in the ipc is227129.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 8:43pm
I could post a photo of it tomorrow. Its at the farm in the wd toolbox. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 9:11pm
I'd like to see it. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 9:35am
Ryan, I'd like to see it also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 10:50am
Has anyone ever seen the lift arm stop?  It bolted under the brake covers, had two stops that went under the lift arms, and a hand crank to set depth.  Looked like it would be in the way to mount and dismount a WD/WD45.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 11:19am
   Is the one pictured in this post it ?:
http://www.rumelyallis.com
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 3:01pm
The first two pictures are of the manual depth control as pictured in some of the Oxnard manuals. It is not mounted on the tractor, I just laid it where it goes to give you an idea how it would look when mounted.  The last two pictures are of the quadrent stop. I posted it a couple of weeks ago. Only a few knew what it was.  It is missing the screw. Michael
Edited by Michael Crowe - 09 Feb 2012 at 4:50pm
