Wd puller
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Wd puller
    Posted: 13 Feb 2016 at 5:07pm
Got a wd puller, removed the hydraulic pump, wondering if I have to refill with hydraulic fluid or if I can use 80-90w gear oil for the bearings
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2016 at 5:18pm
Seems to me the gear lube is higher priced than Un HyTran but I don't know why it wouldn't work, just might lose a 1/4 of a HP with stiffer fluid to turn ???????
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2016 at 12:32pm
While the cases have a little bit of separation, the PTO drive, hand-clutch housing, and transmission/axle will all wind up mixed a little bit. With no PTO gears and no hydraulic pump, the only thing left in the oil is hand-clutch and transmission.
If you've deleted the hand clutch, too, the only thing left in that big cavity is the shaft, so you could probably leave it dry. If you still have any gears or the hand clutch, I'd leave hydraulic oil in it. I don't think the hand-clutch would be all that grippy in 90-wt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2016 at 12:52pm
The hand clutch has been pinned so it won't slip, everything is still in there. Ran gear oil for two years before the rebuild and the hand clutch never slipped. What I'm wondering is if the bearings need hydraulic oil or if gear oil will work. The pto and it's hardware is still there and we still use the tractor to turn a grain auger.
I say just put in hydraulic oil but my grandpa wants to know if gear oil will work
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2016 at 12:57pm
Had this tractor completely tore down to the frame, getting it put back together now, cases and rear end all have a small half inch hole about an inch above the bottom of each compartment
