WD pull tractor
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: WD pull tractor
    Posted: 16 May 2012 at 8:15am
  I just bought a WD that has been used in pulling. It only pulls in the farm stock class,3500,4000,4500. The only modifications I was told has been done was the carburator jets bored.
  What can I do to make it more awsome? I dont want to go into the engine now, maybe this winter. Pulls almost every weekend now, want to pull not wrench. Thought might be some easy HP to get.
   The H Farmalls have been winning them all around here, I bought this tractor to put a stop to this. My Brother-in-Laws is the main one I have got to beat. LOL!!!
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 8:22am
I've read on here that one of the things that you can do is put a spring on it from a 170/175 to give it more rpms.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 9:08am
farm class probably wont allow the higher rpms of the 170 spring.  just depends on the rules used where you pull.  ditching the oil bath filter for something like a K&N will help but probably minimal with a stock engine.  maby a manifold upgrade but i dont think there is much to do without tearing into engine, and once you do that your not really farm class.  so again its about what is allowed i guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 9:21am
paint flames down the sidesLOL
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 9:42am
balance it for the track. Adjust tire pressure to suit conditions and then let it walk.
See what it does. Power Out? Spin out?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 9:54am
I am allowed 20% over stock here. This is new rules this year, they checked at one pull, none could pull, everyone was over rpm'S. So Allowed 20% over in Farm Stock, and Antique..   It is turning around 1580 now, checked it last night.. previous owner, said it's never choked in the 3500# NOR THE 4000#, he ran it once in the 4500 and finally choked it down. I want to spin out in that class too... NO RED ONES EVER DO THAT!!!
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 11:18am
Are you still running a 4" stroke crank. If so I'd at the very least upgrade to a 4.5" WD45 crank. This will give you another 25 cubic inches and better lugging ability. Most WC/WD pulling tractors use this normal in the day dealer upgrade. If you do this you can keep your WD flat top pistons for some serious compression or change to the 45 type "Power Crater" type. Good luck against those binders! Kip
This page was generated in 0.050 seconds.
