WD PTO shaft "U"-joint ??
Doug-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug-KS Quote  Post ReplyReply Direct Link To This Post Topic: WD PTO shaft "U"-joint ??
    Posted: 22 Apr 2018 at 8:53pm
Anyone know what this "u-joint" is for? It was on a PTO shaft of a WD.
Edited by Doug-KS - 22 Apr 2018 at 8:55pm
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 9:13pm
i thought they only used those on the WC? which had a male-male shaft
and the WD had a male-female shaft? AGCO shows the same too, could you use the older shaft if you used it all?
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug-KS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 7:08am
Makes sense, I have never worked with a WC so I had not seen one of these before.  Anyone need one of these or are they worth anything?
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 7:21am
Maybe the male-female joint wore out so they cut the socket off and installed the u-joint? Without having one in front of me, seems like it would work.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug-KS Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 7:23am
Anyone have a use for the u-joint?
