WD- Play in the hydraulics control lever |
john0030
Topic: WD- Play in the hydraulics control leverPosted: 07 Jan 2017 at 8:09pm |
My hydraulics always seemed to have a mind of their own. At first I was adjusting the flow regulator so that the hydraulics would adjust only slightly, but doing this was a real pain. Then I noticed the hydraulics control lever at the steering wheel was moving up on its own. Curious if anyone knows the fix for this? Currently I’m using an orange spring clamp which is perfect for now (no more dismounting and adjusting the flow regulator and control lever then hopping back on). Edited by john0030 - 07 Jan 2017 at 8:11pm |
Auntwayne
Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Posted: 07 Jan 2017 at 8:42pm |
Had the same exact problem, replaced the friction block.......problem solved. Duane
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
MACK
Posted: 07 Jan 2017 at 8:50pm |
Make sure spring is not broken that holds tension on block. MACK
NICKMI
Joined: 15 Sep 2009 Location: Greenville Points: 534 |
Posted: 07 Jan 2017 at 9:07pm |
Try the block first and if that don't do it replace the spring
79fordblake
Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
Posted: 07 Jan 2017 at 9:16pm |
Replaced blocks and springs on mine last week. Along with a new steering wheel, steering shaft, renewed throttle quadrant and lower steering support. Also had both control rods built up and turned down.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 07 Jan 2017 at 10:03pm |
Here's what you need, look in your tool-box, one came in all WD45 tool-boxes.
john0030
Posted: 07 Jan 2017 at 10:24pm |
THANKS!!!
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8627 |
Posted: 08 Jan 2017 at 9:10am |
John,
I agree replacing worn friction blocks and the springs can help assuming they are worn and or weak? Don OK I have never seen one of the clamps you show? And I don't remember one in the tool boxes on Dad's 45's!:) Picture on the tractor? I assume this is a stop for the quadrant handle??? Regards, Chris |
Brian G. NY
Posted: 08 Jan 2017 at 10:25am |
I have never seen one of those either.
I have not happened to see reference to it in the operator's manual either. It is called" STOP ASS'Y., adjusting, hyd. pump lever". It is shown on page 266 of my parts manual under "Tools and Miscellaneous". It is also shown on page 276 attached to the quadrant under the heading "Hydraulic Pump Hand Control". In that illustration, it is clamped on the quadrant below the lever which would indicate to me it is designed to limit how far the lever can be lowered rather than to hold the lever down. Nevertheless, it sure looks like it could be used for holding the lever down as well.
john0030
Posted: 08 Jan 2017 at 10:45am |
Quick question, according to the diagram in the owners manual, it would almost appear there should be a second spring somewhere at the bottom between the end of the lever shaft and the lever shaft arm. is this the case or just one spring up by the quadrant?
Edited by john0030 - 08 Jan 2017 at 11:03am |
Gerald J.
Posted: 08 Jan 2017 at 10:47am |
A unistrut top beam clamp may give the same function as the Allis clamp. http://www.menards.com/main/plumbing/rough-plumbing/pipe-tubing-hoses-fittings-accessories/pipe-supports/pipe-hangers-accessories/top-beam-clamp/p-1444442691705-c-9424.htm?tid=7971912153279451172
Or http://www.menards.com/main/electrical/strut-support-systems/3-8-beam-clamp/p-1444424001789-c-12477.htm?tid=8889206125451875588 Or https://www.lowes.com/pd/STEEL-CITY-3-8-in-U-Bolt-Strut-Beam-Clamp/3306532 Gerald J. |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3994 |
Posted: 08 Jan 2017 at 1:56pm |
don can you toss one of those in my two tool box's it seems like the slightest movement on the quadrant on my wd45 makes it creep up or down but all of my linkages need tho be re biult to take up all the play
NICKMI
Posted: 08 Jan 2017 at 2:19pm |
The part diagram shows the order it goes together spring goes on bottom because that's where it's put on shaft to slide it up towards quadrant with the retainer and pin
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
Posted: 08 Jan 2017 at 2:41pm |
Don, finding those is like finding hens teeth! I've scavenged a4 or 5 over the years and it's always fun when you do find one, but hard to do!
john0030
Posted: 08 Jan 2017 at 3:00pm |
Thank you all!
