WD pick up plow
orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange Quote  Post ReplyReply Direct Link To This Post Topic: WD pick up plow
    Posted: 10 May 2012 at 10:21pm
  Have a wd pickup plow ( known as the round beam) do I have to remove the pto assy. to lift it clear up , Is there any kind of a conversion . It is a pin hitch with leaving the hitch on it removing the bail ,any way to remodel it?
 thanks Terry
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 2:32am
you dont have to remove the pto but if you dont and cross a ditch just right the plow can come up to high and bend or break the pto.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 7:48am
Originally posted by orange orange wrote:
  Have a wd pickup plow any way to remodel it?
 thanks Terry
Probably be worth more as a collectable in the original configuration. If you want an easier way to hook it up, buy a snap couple plow and convert the tractor.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 8:23am
I had to or it would hit
AGCO My Allis Gleaner Company
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 9:24am
Orange, When new it was told in the manual to remove the PTO before using the plow.  It is very possible that the PTO shaft could be bent.  Not worth it.
You do have a collectable.  There were not that many made.  They were initially made from an existing A-C two bottom pull plow so we would have a mounted plow for the WD.
I have only seen one at a GOTO in Union Bridge.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 11:06am
thanks for the replys' and Bill with your answer , what I wanted to know
        Thanks Terry
