WD Patrs
Coultrain63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:07pm
more pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 7:14pm
Coultrain,
 Man that fresh paint looks great! I love that part of the build! Reminds me of a kid putting model cars together! Your tank looks awesome!
Thanks for the pictures!
Not sure if that pulley will work to hand crank it. My guess is you dont plan to hand crank it much?:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 6:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 6:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 7:01pm
Some updates for you fellas.Sorry still cant get the pics right but its coming along!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 7:31pm
Coultrain63,
That fresh PO paint looks Awesome! Thanks for the update on your tractor!
 Chris!
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 9:18pm
Curiosity question, Coultrain63...
What is the cooling fan off of or from?
No doubt about it, that'll sure move some air!
Good looking job to date, too!
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 7:47pm
The fan was on it when I got it. Interesting.  I really never thought about it I just painted it. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 5:27pm
Latest progress...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 6:00pm
WOW... thats one sharp looking tractor !
I had to go back and look at all the PURDY pictures from 2 years ago !  Thanks for the update.
Edited by steve(ill) - 23 May 2021 at 6:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 6:08pm
Im looking for help with all the little sticker locations if anyone has any info.
Thanks!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 8:12pm
This is from a response I gave about a WD45 decal question back in 2010. My tractor is a WD and these pics are from my WD.
The fill battery decal goes on the outside of the left side of battery box. About 1 inch or so from the top and centered front to back. The electrical diagram decal goes on the inside of the top battery box cover. Keep lever down goes on the little flat area on the quadrants left side by the hydraulic lever. Power Crater goes on the left side, lower rear of the engine block (going from memory on the power crater as my WD doesn't have that one). The Snap Coupler goes on the left side of the Snap Coupler bell under the tractor situated on the top half and somewhat centered. The tire one (there should be 2) go on each left wheel anywhere on the smooth face of the rim and somewhat centered. The grease joint goes on the steering shaft itself with the decal  starting about even with the top of side frame and going up from there running lengthways on the shaft. And the shutters one goes about 1 inch below the hole for the shutter control handle on the front right side of the grill shell and centered with the hole. If your 45 didn't come with a distillate engine then you won't have this hole I believe. Hope I made sense. Here are pictures
This is the battery fill
This shows the inside of the battery lid w/ electrical diagram
This is where I believe the power crater goes
I forgot to get a picture of the snap couple but I think my description show work
Front left wheel
I couldn't get a good shot of the rear left but this is where it goes if this were the left wheel
Here are some others
This is supposed to be centered on the box but in an original film I spotted one that was off center so I put it off center to copy the one on the film
this is the patent numbers on the right hand side under fuel tank
Edited by Lonn - 23 May 2021 at 8:19pm
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 8:16pm
Not sure that the Be Careful decals were part of the original WD decals but it's what Wacker Decals gave me several years ago. Sorry about the dumb photobucket watermarks as photobucket claims my photos belong to them. Angry
Wink
I am a Russian Bot
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 11:24pm
nice looking tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 6:06am
Sure is looking awesome! Thanks for the update!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 7:13am
That Tractor needs a nice new B&B wiring system on it!  LOL!  Great lookin' Tractor!  Nice job!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2021 at 5:17pm
Thanks for the help guys! Its been a really fun project.
This page was generated in 0.211 seconds.
