WD Patrs
Coultrain63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Topic: WD Patrs
    Posted: 24 Nov 2018 at 3:31pm
Looking for some help with parts I am having trouble locating.  I need a gasket between trans and hand clutch housing and the vertical steering shaft bearing/race for a tricycle front. I have Hyatt bearing numbers but didn't have any luck that route.
Thanks.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 7:50pm
Agco dealer should have them. I've gotten that gasket from my local dealer a couple of times. The bearing and race I've not bought but would think they would have too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 8:54pm
I tried an Agco here in Illinois and never got a call back. Do you have a Phone #? i dont mind ordering out of state.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 7:23am
Central Iowa Farm Store, Marshalltown Ia. 641-753-3996. Talk to Reed or Matt in parts. These guys both have WDs and know what you are talking about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 9:46am
Coultrain63,
Nice to see someone with fresh PO#1 on tractor parts! Welcome to the forum.
I have the vertical shaft bearing part numbers somewhere in my WD45 thread. These are not the original barrel type. But I think they should work OK. I bought them from KAMAN.
Sounds like you have a local source mentioned above. We need some pictures of the rest of your project.
Your paint looks awesome! Love final paint!
By the way are you replacing the bearings and races on each side of the worm gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 10:17am
I think theses may be the bearings I used. Not sure I have so many pictures of bearings? Top seal doesnt look right? Looks too small?
Another supplier would be Sandy Lake if you run out of leads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 10:34am
Coultrain63,
I will put up some more pics. I guess I can only do one at a time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 10:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 10:45am
Here is the gasket I need. Sorry about the rotation-haven't figured that out yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 10:56am
Current status
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 11:32am
Great shop and the WD is coming right along! Thanks for posting these. You should be able to post more than one one picture at a time too, so not sure why you cant?
Sandy Lake and or other AC parts folks on here should be able to provide that gasket. BTW I am going to need one sometime soon also. I am going to try to get mine split in the next few weeks.
What are you using for primer and paint? It looks good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 2:13pm
Using AG SPECIALTIES paints.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 2:17pm
Coultrain63,
Worm gear bearings are OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 2:21pm
Thanks for the tips guys, I will make some calls tomorrow.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 3:42pm
that gasket doesn't look that complex.  get a sheet of gasket material and ballpeen out your own gasket.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 5:16pm
Best I can find on DJs tractor parts is a hand clutch shaft seal, but don't see a gasket.
Don't forget there's two cork gaskets that go in the spindle as well I think. I saw sugarmaker repair his the other day and was looking at buying some for my own tractor.
Also that WD looks pretty fantastic; great job so far!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 5:33pm
I thought about making a gasket but if the thickness isn't right i'm afraid the lash on the bearings wont be right.
Not sure what you mean by corks on the spindle.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 6:44pm
These are the two cork gaskets related to the pedestal from what I can tell:
Maybe these are part of the steering assembly and not the pedestal itself though... I haven't torn into mind yet as I am trying to figure out what parts I need. Here's sugarmaker's relevant post from his "WD45 next? YES!" thread.
Ok It was a slow day.
Heres a shot of the old WD that I put in storage, guess I needed a picture of a complete tractor!:):
Worked on the WD45 front pedestal assembly:
Installed the front expansion plug. SM says apply some sealer, I used gray silicone.
It doesnt say that you need to put it in with the concave side towards the front and then gently flatten it out  from the back to seal against the sides:
Next was the new bearing race in the bearing cage:
Then the race in the front of the perdestal:
Then the new cork seals and retainer:
Dont forget the spacer that goes between the worm and the back bearing.
Bearing installed on the front of the worm. Grease to be applied.
Now to install the spacer and back bearing, on the steering shaft, and begin assembly. Also a shim/s in there too! (page 57 in your manual)
Feels good to be assembling finally!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 7:27pm
Folks,
Make sure were are talking about the same parts. I am sure not a expert here.
On the large vertical spindle in a narrow front there are two seals. I used lip seals for these.
 The two small 7/8 I.D. cork seals in my pictures are the ones at the back of the pedestal on the horizontal shaft turning the worm gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 7:54pm
Folks,
Yes thanks just to clarify I am talking about bearings for the lower vertical shaft. and a gasket where its split at the trans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 5:44pm
Here is an update fro you guys! working on the sheet metal now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 5:56pm
Anyone know where I can find a few of these?
albrown915 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albrown915 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 7:07pm
Fastenal
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 8:54pm
...or get a chunk of angle iron from the welding shop and cut some out.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 10:03pm
mcmaster carr has them
use "leveling washers for I-beams" in the search
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 6:30am
Looks like it will be really nice when done.
What the funny looking thing of front of the crank pulley?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 10:44am
Coultrain,
Looks great! More pictures! Please.
I was wondering the same thing on that pulley? Haven't seen that version? What does the shaft look like?
Just noticed the different fan too.
Also what did you find for vertical spindle bearing?
Wish mine was that far along! its a lot of moves to get them old WD's to look that good!
Edited by Sugarmaker - 18 Jan 2019 at 10:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 12:49pm
Coultrain,
The pulley was repaired at some point. looks like it may have been being used for something-not sure what. I got the spindle bearings from the central Iowa farm store. Great guys there.  Ill try and post more pics later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 12:57pm
Coultrain,
 Did you replace the 3 seals in the torque tube? I plan to put in new ones at some point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coultrain63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 5:49pm
Coultrain,
I did not tear it down that far.
This page was generated in 0.477 seconds.
