WD or WD45?
brettIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 8:33pm
read that whole post you found. they talk about the rod length and different combustion chamber . with some work you may be able to fit an allis head and up the comp?
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 8:34pm
From the looks of your photos, it has a IH distributor and since you have a mag flange mt.,  that would have been on a WC/WD 201 engine.  Since your Tractor s/n is less than 146607 that would also indicate a WD.  Obviously you can tell if its a 45 by pulling a sparkplug and measuring the stroke.  I can't explain the plate on the block.  As for making it a puller, the head is the same, it has a "stock block" so it should be no problem.
ashbrook View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashbrook Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 9:17pm
i would say the block is a gleaner E motor block. i got this from the picture of the cover you put on here. it covers where the fuel pump went in to to block. looks the same as mine and my cousins gleaner e motors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 9:58pm
It's a LeRoi engine, maybe a distant cousin to WC,WD, 45, or Gleaner engine?????
So now that you know you have a LeRoi, ask around to find out if this model has a combustion chamber in the head. If it does, the head could be milled to increase compression. Where is Mitch on this thread?
Edited by CTuckerNWIL - 25 Apr 2011 at 10:01pm
This page was generated in 0.123 seconds.
