WD or WD45 block?
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2014 at 5:49am
dawntreader USAP mod and NATPA div 3/4/5 you can pull a 17 or e block you people from chicago need to get with it you can look here http://www.natpa.com/rules.htm or here http://www.usapuller.com/USAP-Rules.html usap says ag blocks itpa say Tractor must have OEM external dimensions cast iron block and crankcase.http://www.itpapulling.com/tech.aspx
Edited by patrickmull - 08 Mar 2014 at 6:10am
Jasonillinois View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2014 at 7:13am
As I said before d17 Wd-45,Wd,Wc can be used in 2T and up. For Natpa. Otherwise it's oem block or Factory replacement.
