Wd oil pan removal |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1269 |
Topic: Wd oil pan removalPosted: 13 Jun 2025 at 11:39pm |
Good evening a’ll
Decide to pull the engine pan to see what was in there due to finding dirt/ sludge on the dipstick. Found the oil pump screen almost plugged and lots of sludge in the bottom of the pan. Should I check/ do anymore than clean it up and reassemble? Ran just fine (as of the last it got ran a couple weeks ago) but thought I might try to prevent problems from happening. I’m putting new crank seals in and wouldn’t mind some advice on the rear one…. |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2580 |
Posted: 14 Jun 2025 at 5:31am |
Flywheel has to come off to do the rear main. Watch this video and do EXACTLY as he says to get the pan seals done right. AaronSEIA
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3164 |
Posted: 14 Jun 2025 at 6:38am |
The guy that used to work on our tractors years ago removed the oil pan on a WD NF for us and put it back on while it was on the tractor.
kevin LA-CA
Joined: 12 Sep 2009 Location: california Points: 76 |
Posted: 14 Jun 2025 at 8:37am |
It can be done on the tractor. It will be frustrating.
One key iin addition to the other hints- remove front engine support. It pan looks like it should fit, but just keeps knocking off the front gasket. Use the short set of end gaskets for WD motor. Two sets are supplied in each pan gasket kit. Can anyone confirm that front seal can be replaced without removing front timing cover? |
55allis
Posted: 14 Jun 2025 at 9:08am |
I will be removing the engine to get to the clutch do to the possibility it is oil soaked…
Never pulled a flywheel off a 4 cylinder.. Thanks!! |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8872 |
Posted: 14 Jun 2025 at 1:05pm |
Have your belt cinched up tight. They are heavy. Bolt hole are not even spaced will only fit one way.
