WD Not Starting - Looking for help
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 4:26pm
Just to be certain- the kill switch should be open, not closed, to start. On aftermarket switches, this will be the “off” position.
Edited by HoughMade - 05 May 2019 at 4:27pm
1951 B
bhaynes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhaynes Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 8:42pm
I have tried it with the switch on and off and the actual kill switch wire completely off too. Tried everything. I believe it is bad or I am missing something beyond my expertise in it. I have reached out to some to see about help.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 9:34pm
Sounds like you need some personal attention to do this for you.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhaynes Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 9:57pm
Pretty much! :-) I’ll be reaching out to the local Co-Op to see if they can help / work on it or if they know anybody.
It sucks this is the only thing stopping me from getting it kicked over after 2 years. Haha
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 4:47pm
Originally posted by savedallis1953 savedallis1953 wrote:
I once owned a 1938WC, beautiful machine. The mag would make spark when held in my hand and turned over with a thumb over the plug wire holes, oh yeah. Reinstalled it and timed it with the "F" on the flywheel and cranked a few hundred times in all "correct" positions and with #1 in compression stroke.So for the meantime I Fab'd a battery box and installed a distributor starts every time, even after sitting for 9 years. I guess I am a procrastinator.
 You don't time it to the F unless it's running and you have a light on it. F is fire and is not used for static timing. TDC is for static timing the mag. I doubt it would ever pop, if you time it o the F mark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhaynes Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 4:54pm
I don’t know what your talking about. LOL - however, the magneto itself isn’t generating power. I have tested the magneto every which way. Watched videos, posted posts on here, tried others suggestions. Etc.
No spark is coming through at all. What I have done though, it set the #1 piston to TDC. Then put the magneto cap to set at 1. Put it all back, plugged the wires up properly. Nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 5:07pm
So....maybe you have a bad magneto then?  Have you checked the points?  Have you checked the resistance of the coil?
1951 B
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 7:30pm
Is there any chance the stud that the kill switch is connected to is grounded against the mag housing or the wire to the stud has come off inside? I believe it is supposed to be insulated from the case. Hope I got that right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 8:35pm
b,
 Guys that know the electrical on these old mags make it look easy to trouble shoot problems. Or even electrical in general. When we had the mag on the WD when it worked it was great. When it didn't Dad had to get the local expert to stop and get it working.
Edited by Sugarmaker - 08 May 2019 at 6:49pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2019 at 9:48am
I'm teaching class's to help first time tractor owners to the more advanced with questions.
http://www.allischalmers.com/forum/class-on-why-wont-my-tractor-run_topic159525.html
