wd no power
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: wd no power
    Posted: 01 Jun 2014 at 8:27pm
Had the first hook on the wd today and i was very embarrassed at the outcome it went 54 feet in first gear and full throttle. it has 15-5-38 tires on it. What can I do to it with out bilding the engine. The tractor is bone stock or is the carb just to small. Need help please
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 8:49pm
And, you killed the engine, right??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 8:55pm
Yep
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 8:59pm
you need to put the right wheels an tires back on it 28' not 38s. that will sure help. i pulled one for a lot of years with the stock wheels an tires an did very good with it GOOD LUCK'
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 9:03pm
Thatd what I was thinking can I do anything else? I don't have a good set of tires that r smaller to use and I don't have a lot of money to spend
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 9:20pm
Well, a WD45 would be a lot better than a WD for 2 reasons.....more HP and a slower low gear. Anything you do to increase a WD's HP will cost $$$$$.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 9:41pm
Get a wd45 motor and 18.4-28 tires. That's what I'm pulling with right now, I'm not winning any championships but I run up there with the rest if them. If you decide your looking for a wd45 let me know I've got one I can hook you up with on a decent price with 18.4-28 tires in ok shape and a GOOD motor. It's stock but its got loads of power for those tires!
1950 B, 1952 pulling wd, and 1954 wd45
Jasonillinois View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 9:48pm
Either change the tires, drop a combine engine in it or change out the rear end gear. Or any combo of above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2014 at 10:22pm
there is a lot of old combine wheels an tires out there cheep 26'with 8 hole wheel will fit on a wd. i know there out there would even be better then 28s you will have more motor also
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2014 at 7:02am
I have a built combine engine, cam and everything, a complete engine, ready to bolt in, we were keeping it for a spare. We out grew it and have decided we are not building a second tractor. If you interested let me know, also I have a set of nice 16.9x26 on 8 bolt wheels. With that engine and those tires we never had a power issue even at 5500#.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2014 at 3:26pm
I think I'm just going to put smaller tires on and the bill the engine down the road would it help to put a different carb on and if so what brand or model
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2014 at 10:18pm
I was wondering if I put a pair of 26es on the rear what would be the best for the front I won't it to set down in the front any ideas
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2014 at 10:22pm
Get a weight bar on the front, and keep moving weights until you are either winning or having fun, whichever comes first!
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 8:56am
id tell you to put a wc trans in place of the hand clutch to gear it down to run those 38s but some people on here think its stupid. Do you pull in a speed limit class?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 9:12am
I was thinking bout a dual Trans but I don't no if that would be a loud hear and yes thear is a speed lime .
I use this tractor to move wagons in the barn and I plow with it and am planing on using the pto so I need the hand clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 11:40am
you will still have a pto but hydraulics will be gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 11:44am
Well I use a snap cupler plow so I need hydraulics
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 10:09pm
ron' just put the smaller wheels an tires on an a wd45 carb on tune it up some will work just fine an you can still use it also on the farm an know one will bitch about not being stock it will also pull fine. LIKE TO KNOW HOW IT HELPED ''
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 10:16pm
Where are you located? I may have wheels and tires if you're close. I have good 14.9x28's on power adjust rims
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 11:55am
I am located in pa bout 30 mints north of Pittsburg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 12:01pm
I was just looking to trade even up tires the ones I have r almost new new tubes they r 15-5-38 on power adjust rims came off of a 6060 allis
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 12:10pm
Can I put those 38's on my D17? Think they would do better than my 16.9x28's?
Charlie
I need those for me CA LOL
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 3:14pm
Located in pa 30 mints from pittsburg
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 4:31pm
Im just outside State College, Pa if youre interested
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 4:32pm
I may be interested in the ones you have.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2014 at 11:08am
Benny can u send me pictures of the tires u have 724 622 8323 and do u have the centers for them. the ones I have to trade have center that go with them
