WD NF to WF |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5311 |
Topic: WD NF to WFPosted: 25 Nov 2025 at 7:42pm |
Quicker to ask instead of researching, changing my NF WD to WF. Is the steering shaft the same length for both?
VaAllis1990
Joined: 26 Jan 2022 Location: Champlain Va Points: 28 |
Posted: 25 Nov 2025 at 7:52pm |
Should be the same
Gary(VA)
Joined: 13 Sep 2009 Location: Troutville, VA Points: 342 |
Posted: 26 Nov 2025 at 3:37am |
I’ve done it once and remember no issues with steering shaft
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8729 |
Posted: 26 Nov 2025 at 9:43am |
Same
AC720Man
Posted: 26 Nov 2025 at 11:18am |
Thanks to each of you for your reply’s back. Hope to start on it next week.
AC720Man
Posted: 13 Dec 2025 at 11:19pm |
Spent 2 partial days removing the NF and installing the WF. The steering universal joint was a bear to remove, well mainly driving the pins out. Had no luck driving it out so I decided to drill it out. Got a 1/8” carbide drill bit thru, went to the next bit but snapped off right before exiting the other side. It felt like it grabbed hard and snapped. So, my buddy Mutt pulled out his torch and he proceeded to get it red hot as I started to drive the pin. Finally after a half hour of pounding the pin came out. Drove it off the shaft and then removed the NF. The next day the process of getting it off the steering shaft started the same way but I couldn’t budge the pin until once again heating it cherry red. Finally drove the pin out. Tried to drive the universal off the steering shaft, even with it red hot it wouldn’t budge. The universal needed to be replaced because it was worn out so I asked Mutt to cut the universal parallel to the shaft with the torch. He did so without damaging the shaft. After some pounding it finally came off. Installing the new used universal joint was simple after cleaning up the shafts. The rest of the WF install was pretty easy. It’s all back together for the new owner.
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4793 |
Posted: 14 Dec 2025 at 11:29am |
My WD45 that I gave to my kid has a quick change front end on it. Takes 15-20 minutes to swap out to a narrow, wide or single front. I have all 3 fronts for it. Not sure when or what models had this option?
Waukesha B, B, IB, G, styled WF, D17, 615 backhoe, 2-Oliver OC3's, 5 Ford Model T's, 3 Model A Fords, 34 Ford coupe, 57 T-Bird
AC720Man
Posted: 14 Dec 2025 at 9:32pm |
I never knew that existed on the WD45. I would like to see some pictures of that. That has to be rare.
Oddly, the new owner didn’t want me the install the power steering on it that I purchased for it a few years ago. I will possibly put that up for sale at some point. He said his dad’s WD didn’t have power steering so he didn’t want it either
AC720Man
Posted: 14 Dec 2025 at 9:35pm |
Posted: 14 Dec 2025 at 10:07pm |
If you have a wide front end already, you drop off the axle assembly and unbolt the swing arm from the steering box, leaving the steering box in the chassis. Clean off the bottom of the mounting surface where the swing arm attached (running a thread tap into all holes and cleaning them) and simply install the narrow front post (or single front wheel fork) and you now have utilized the "interchangeable front axle" design. The six bolts that hold the NF post or single front wheel fork are fine thread and grade 8. They must be lubed when installed and gotten TIGHT and kept tight.
Edited by DrAllis - 14 Dec 2025 at 10:08pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4191 |
Posted: Yesterday at 4:13am |
That was/is a pretty handy feature! When I went through the WFE on Fred, bolted a 'corn-picker' tricycle front pedestal on and the tractor was not down for any time. Never been lucky enough to find a SFW for a reasonable price.
SteveM C/IL
Posted: Yesterday at 8:47am |
Uncle had the "corn picker" narrow front to put on his wide front 45 when mounting the picker. I suppose most of them have been tossed by now.
AC720Man
Posted: 21 hours 48 minutes ago at 10:14am |
Interesting, thanks.
