WD Loader
Jimdril View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimdril Quote  Post ReplyReply Direct Link To This Post Topic: WD Loader
    Posted: 04 Feb 2010 at 4:44pm
I want to haul a bunch of stones up a grade with my freeman loader. Would I need to some weight on the rear? If so, what kind?
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 5:58pm
We have wheel weights, and CACL in ours.   Ours still gets front heavy, so, yes, I would think you would need something.
Greg Kroeker
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 6:23pm
 Keep your bucket as low as possible and BACK up the slope, you still need ballast.Widen your wheel tread as much as you can , too. Gary
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:47pm
I have never used a loader tractor that had to much weight in the rear, I would think you will need some weight back their if you plan to carry very much in the bucket at one time.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 9:56pm
Jim,  Just be VERY CAREFUL!  I have lost several good friends and customers on tractors with loaders.
Listen closely to what Gary says.  Keep it low.
Good Luck!
Bill Long
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 12:43pm
I hook up to my 8 ft. snap coupler disc when I need extra traction on my WD.
Simple and fast way to add and remove rear weight.
Gary
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 1:04pm
I tipped mine over on basically flat ground. I had the bucket low but it slowly swung over til it met the radiator then the tractor started tipping. The further it tipped the higher the bucket went even tho I had the lever all the way down by then . It was slow enough that I was able to get off and out of the way. It was a HUGE rock I was moving and the tractor was a tricycle.
Just be very careful. It's amazing how easy it is to tip a tractor.
mojo/Mike
