WD lift problem
Embellem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Embellem Quote  Post ReplyReply Direct Link To This Post Topic: WD lift problem
    Posted: 13 Dec 2010 at 1:04pm
I had posted a couple of weeks ago that the lift on my WD sticks in the hold position. Well, the problem isn't with it sticking. I discovered that the lift always lowers fine if I move the control lever past the bottom of the quadrant (that is, the lever is lower than horizontal). But if I just move it to the bottom of the quadrant, it may or may not lower. Is there something I can adjust to remedy this?
Thanks
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 1:08pm
yes, follow the rod forward and there is adjustment there.
This page was generated in 0.404 seconds.
