WD lift cylinder help
Freewheelin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheelin Quote  Post ReplyReply Direct Link To This Post Topic: WD lift cylinder help
    Posted: 05 Dec 2016 at 3:10pm
One of the hydraulic cylinders on my WD leaks pretty bad.  It appears as though it's leaking around the threads on the end nut and not from the seals.  I removed the end nut and there seems to be a ding in the tread but not across all of them.  The ram shaft looks very good with no nicks, scratches, or pitting so I'm thinking of just replacing the packing and see if that does it.  The kit from the Agco dealer is about $20 which I assume is just the chevron seals.  Is there anything else I need?  It appears as though I have to unscrew the end section of the housing to remove the shaft.  Correct?  Any rebuilding suggestions and a schematic would be greatly appreciated.  Thanks.
Bassman62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassman62 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 5:58pm
Don't know if this will open for you but it is a page out of the Operating Instructions Maintenance and repair parts Illustrations for a WD.
Bassman62
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 8:13pm
This might help;
Danny
http://s577.photobucket.com/user/dannyraddatz/library/Rebuilding%20Allis%20Chalmers%20Loader%20Cylinders?start=20&page=1
I also know he had a thread on here where he walked you through his pictures.  It was really informative and should have been put in the Farm Equiptment - Knowledge Base.  I'll keep searching, but it doesn't look too good right now.....
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 9:59pm
Don't unscrew the cylinder! Might just need to tighten nut on end of cylinder. If you replace packing, with arms up, remove nut and push down on arms. In a lot of cases, that will push the packing out. May need to do some diving with screw driver.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 10:34pm
Put packing in years ago and don't remember a thing about it! LOL! Always tighten the nut first.When the nut is bottomed out then you repack
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 10:50pm
One thing I have noticed, I believe advice is being given on two different cylinders. I think some are referring to the rear, and some are referring to the front lift. If it is the front lift you are referring to, all I did was loosen the four square head bolts that holds the compression cap, slid the cap up, pried the old chevron packing out, worked new chevron into place (cut the ends on a angle for a good lap seal) and replaced the compression cap, walking it down evenly. I've had the rear ones apart, but like SteveM, memory is failing me on that one
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheelin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 3:07pm
Thanks but the cylinder I'm working on is the rear one that moves the Snap Coupler lift arm.  Guess I should have been clearer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheelin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 3:11pm
I tried tightening the end nut.  That's when I noticed that the leak didn't appear to be around the shaft but rather from the end nut screws into the cylinder housing.
