wd lift arm hydraulic hoses
Jaybird14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Topic: wd lift arm hydraulic hoses
    Posted: 11 Nov 2024 at 8:12am
please help.
I need a supplier for my WD's rear hydraulic hoses.
Thanks!!
Jay
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 8:18am
You can do to any local place that makes hydraulic hoses to make you some. I had the local John Deere dealer make mine. Most NAPA stores can also make them. Mkae sure they use at least 4000PSI hose. You'll want a swivel on one end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 8:21am
Pretty sure we have both. I’ll double check and get back to you
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 2:24pm
Take your old ones to a local hydraulic shop. They will make new ones.  Have done it many times.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 9:04pm
My local industrial hydraulics outfit is the NOTT Company.  I carried in a hose, they made a replacement.
One necessary piece of knowledge, is that tractors prior to the early-mid '60's most frequently used high-pressure/low volume hydraulics... that's 3-5000psi, and fairly small-diameter hose.  60's on, most went with low-pressure/high volume, so 1000-2500psi or so.
The WD rear lift cylinders are high pressure low volume, and will be fairly small ID... 1/4" probably.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 10:16pm
I got mine from Agco a few years ago. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybird14 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 6:24am
could you order them on line?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 7:11am
Allis Chalmers was the only company to use a High Pressure Low Volume hydraulic system, All others used a low pressure system. Some were as low as 1,000 PSI.
 www.SurplusCenter.com has good quality hydraulic hoses and most likely half the price for the same thing you'd get made at any local shop, using the same components.
