WD HYDRAULICS PROBLEM???
Geppy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geppy Quote  Post ReplyReply Direct Link To This Post Topic: WD HYDRAULICS PROBLEM???
    Posted: 07 May 2012 at 8:29am
I just brought out my new to me WD yesterday to do some field work, after raising and lowering the 3-pt hitch I hooked on to my plow and BAM the hydraulics wouldn't lower. It raised all the way up and stuck, I had to crack open the line at one of the lifting cylinders and it went down. I did this a few times and it still won't lower. Any ideas what I can do to fix this? Oh ya it has new hydraulic fluid too.
Edited by Geppy - 07 May 2012 at 2:52pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 10:04pm
Control valve in pump is stuck. Pump needs torn down valves polioshed and every thing cleaned up.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Geppy Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 4:20am
How do I polish them Mack?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 6:37am
Use some fine laping compound. Chuck the spool in lathe or drill and lap spool to outer body. Some times a check spring will break and get in valve.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 7:01am
I would screw the volume control screw all the way in and out a few times with the arms up and weight on them. It is on the front of the hydraulic unit.
This page was generated in 0.329 seconds.
