WD hydraulic relief valve
pleman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pleman Quote  Post ReplyReply Direct Link To This Post Topic: WD hydraulic relief valve
    Posted: 22 Sep 2016 at 3:58pm
Bought a 1953 AC WD. The previous owner had low hydraulic fluid so the lift arms worked fine. When I added oil to the correct level and raised the arms, the relief valve did not work and oil spurted from every gasket. How do I check/repair the relief valve?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 9:42pm
There is no relief valve in WD hydraulic pump, it is a unloading valve. It is shim adjusted. Pump has to be removed and taken apart to be adjusted.
 Disassembly pump, clean and polish all spool valves, replace o rings and reassemble.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote pleman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 6:45am
Thanks.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 6:48am
I agree with Mack. Something must've stuck. I'm not sure what the low oil level would matter unless it was almost out of oil, which would be bad for the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 10:00am
Before tearing things all apart, check to see exactly what pressure you have.....3400 psi is the max spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 10:18am
Doc has a good point, unless it's leaking so bad now, that you can't use it. By a pressure gauge put a coupler on it to hookup to the hydraulic remote to check pressure.
