WD hydraulic ram leaking
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WD hydraulic ram leaking
    Posted: 11 Dec 2010 at 6:50pm
Hey all, put oil in the WD the other night and noticed that I have one ram leaking more than I would like it to.
What are the pointers on repairing rams? I have never tackled this, are there a couple seals to replace? Thanks, Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 7:40pm
Try tightening the packing a little first. If the nut is bottomed out you will need packings. Just don't over tighten. These packings have to let a very small amount of oil through to keep themselves lubricated.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:28pm
If it is a AC loader turn the packing gland on the top of the cylinder down a little and it should stop. They need to leak a little like CTucker is saying. If the packing will not tighten any more they will need to be replaced. The packing shouldn't cost much and once you start taking things a part you will see how they work.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
