WD Head Gasket |
JD-Ohio
Joined: 22 Oct 2009 Location: Columbus Grove, Points: 39 |
Topic: WD Head GasketPosted: 08 Aug 2022 at 1:42pm |
Looking for the disassembly procedure to replace the head gasket on a WD.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5188 |
Posted: 08 Aug 2022 at 3:23pm |
it's a pretty straight forward procedure. Drain coolant, remove hood, valve cover, rocker arm shaft, push rods and head bolts. If there is no reason to remove the manifold, leave it alone. Carefully remove the head, making sure you have a good place to set it down. Head gasket failure is not usually a problem in the 201 or 226 AC engines. I'm not saying it's not the problem, but a lot of head gaskets have been changed without fixing the initial problem. If you have coolant in the oil, DO NOT REMOVE THE HEAD! Pressurize the cooling system and try to find where the coolant is coming from (it will almost certainly mean removing the oil pan). Find out the source of the leak before you remove the head. A few possible causes may be a hole in a liner (sleeve), defective O rings on the liner, a crack in the head or block, etc., but the first step is to find out what is causing the problem, rather than throwing unneeded parts at it.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3252 |
Posted: 08 Aug 2022 at 3:37pm |
May be totally different but I just dealt with this on my gas D 15. Auto Zone had a $250 loaner pressure tester that worked for me. Good luck!
