WD handclutch lever bushings
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: WD handclutch lever bushings
    Posted: 07 Mar 2012 at 8:59pm
   Looking for the dimensions of the handclutch lever bushings, and if anybody has part numbers other than AGCO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 9:59pm
Don't think there were ever bushings.Just pin and bore.They say you can drive pin out from inside and drive new one in,then get your lever bored and sleeved for a "like new" fit.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 10:27pm
It's been many years buy I'm pretty sure I bought bushing(s) from Allis back when it was Deutz-Allis. I know on my WD I installed bushings and I think it had a them in already.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 5:55am
Got mine in La Crosse at 'Lackore Electric Motor Repair', an electrical supply house. There is one in Winona, MN too.  I don't remember what I paid for them though.  It was a couple of years ago.  Here are the addresses:
108 W 2nd Street
Winona, MN  55987
Phone: 507-452-3103
4102 Mormon Coulee Court
La Crosse, WI  54601
Phone: 608-782-7635  or
Phone: 608-783-8012
Check in your area for any Electric Motor Repair places.  You might have some good luck.
Oh yeah, I think they were 3/4" I.D. x 7/8" O.D.  if memory serves...  Most of the time it doesn't, if you know what I mean...  LOL
Edited by Ted J - 08 Mar 2012 at 5:58am
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:58am
Yes, agco has them, Part #70224705 requires 2 pieces, very spendy
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:31am
The lever was bushed with two bushings eff. tractor ser. #34450 and up.
I would guess (once you determined the size needed) you could buy bushings much cheaper some place other than Agco.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 9:01am
I re=bushed both the foot clutch pedal and the hand clutch pedal on my WD45.
Here's the pivot point measurements I took for each:
* Foot clutch:  ID: 1.00", 1.75" long
* Hand clutch:  ID:  7/8", OD: 1", 2.125" long
I priced the hand clutch bushing from AGCO.  Part number 70224705 was $33.88 EACH and it takes two.  I went to McMaster-Car instead.  Ordered part number 2868T192, a Bronze SAE 863 bushing 1.5" long.  Cut it in half and put one half in from each side.  Price:  $2.68.
The foot clutch did not have a bushing so I drilled it out to 1 1/8.  I ordered TWO 2868T201 Bronze SAE 863 bushings 1" long for $1.75 each.  Cut one down 1/4 inch to get to 1.75 total length and installed both in the foot clutch.  My pivot shaft was worn a bit so it's not perfect and not all the wobble is removed but it is about 300% better than before.
HTH.  Mike
Edited by Skyhighballoon(MO) - 08 Mar 2012 at 9:03am
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 9:08am
Mike;  are you going to the Derry Brownfield auction this weekend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 11:00am
    No, I'm not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 12:32pm
Originally posted by Mike56073 Mike56073 wrote:
    No, I'm not.
LOL - That comment from Joe was for me I'm sure.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
