WD hand clutch
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: WD hand clutch
    Posted: 20 Jan 2016 at 6:31pm
Has anyone tried making a WD/WD45 hand clutch with 4 or more discs? Just sitting here bored tonight curious if one could make a stronger clutch for pulling beyond the WD45 3 disc setup? Would probably need spacers where the shims normally go and machining of the collar to allow extra space.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 6:53pm
Maybe, but the splines on the transmission input shaft are only so long, there may not be enough for a 4th disc. Anyway, serious Pullers eliminate the hand clutch for zero slippage problems and a loss of 25 to 30 pounds in weight.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 7:46pm
  can put 2 hand clutch connectors and bolt them together hve done some for that purpose
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 10:17pm
Had a 4 plate setup for a while.Had to make shorter links for the over center mechanism and welded a spacer to where the shims go.Think the link difference and spacer thickness was 5/16.Takes 2 shortened springs per hole with short wire inside to help keep aligned.Just remember the plates have the hubs mounted in different ways depending on location so you have to use the correct ones.
Edited by SteveM C/IL - 20 Jan 2016 at 10:19pm
