WD hand clutch seals install
JC'S 53 WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC'S 53 WD Quote  Post ReplyReply Direct Link To This Post Topic: WD hand clutch seals install
    Posted: 17 Jul 2012 at 2:22pm
i saw a post on here and now i cant find it in regards to the hand clutch seals and thanks for that info.
my question is how hard is it to change these? i have sealed all other leaks and this one seems to be getting worse. thanks for the help.
i always come on and read and never log in i have learned alot about keeping this WD going which has been in my family since 1955. thanks again
Larrywdin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larrywdin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 6:05am
It's not a bad job JC, the old seal, (if it's not been changed already) will have made a groove in the shaft that goes through the main casting.
The kit you should get has a speedy sleeve and two seals with it.
pay close attention to how they go back in, cause in my late WD they show the seals going in back to back,,for some reason, other WD45's it looked to me like, they don't.
Maybe someone on here will know why, I just followed the instructions (something I don't usually do well) and I used a piece of 2" PVC pipe  and a hammer to drive them in with.
The speedy sleeve on the other hand was a tight fit.
I took my shaft to a machine shop a couple of blocks away and had them press it on the shaft,
I've been told you CAN use a propaine torch and carefully heat it so it'll go right on..
here's the kit,
 and how it goes on,,
sleeve pressed on,
seal install,,
 and what it will look like when it's done,
 hope this helps ya!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 1:55pm
The old original seal in my 45 was one piece with lips facing away from each other. Replacement was 2 seperate seals and instructoins said to place them "back to back" like Larry says. My hyd oil still gets into the transmission.
