wd hand clutch seal
gman11110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Topic: wd hand clutch seal
    Posted: 12 Dec 2011 at 7:35pm
the hand clutch seal is leaking on my 49 wd.  i have the engine out right now.  whats the best way to get to it.  any info is appreciated
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 8:12pm
   pull the next casting an replace it
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 8:24pm
Which one? If your talking about the input shaft seal between the hand clutch and hydraulics you need to do as Norm advised, pull the next casting foreward, the hydraulic tank. Symtom of this one is your hydraulic oil seeks the level of the trans/rearend oil. Some have been "fixed" by running hy/tran oil in everything and lettting it go where it wants to.  I dont remember there being any hidden tricks to doing it but there is an old update to a dual seal which is all you can get now and there is a wear sleeve that you must have to use it.
Edited by Butch(OH) - 12 Dec 2011 at 8:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2011 at 7:16pm
the seal that is leaking is on the side behind the brake pedals.  it is where the lever for the hand clutch goes into housing???
This page was generated in 0.848 seconds.
