wd governor |
3rdgeneration
Topic: wd governorPosted: 21 Oct 2010 at 6:00pm |
I have a wd and the problem i am experiencing is when i fire it up it runs wide open. I shut the tractor down immediately because i know this is not right. I am assuming that there is a problem with the governor. Does anyone know the proper adjustments of the governor or have a diagram of how it should be assembled. I have searched different places on the internet but have not been able to find any info on how i should fix this problem. I would appreciate anyone knowledge.
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 21 Oct 2010 at 8:30pm |
need to pull the gov sounds like the weights have broken off . this is what caused me to rev my puller above the rpm range I had it set for. With the tractor off the throttle pulled wide open the carb should be wide open with the carb rod being about a half the hole long meaning the cross shaft needs to be pulled back towards the radiator to preload the gov. I think the measurement is a 32cnd
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1733 |
Posted: 21 Oct 2010 at 10:18pm |
i have a govenor set up complete for sale,
CTuckerNWIL
Posted: 22 Oct 2010 at 7:56am |
Models WC-WD.WD45-WF
119. ADJUSTMENT. Adjust engine speed by shortening or lengthening control rod (5—Fig. AC52F) by using set screw (4). To adjust linkage follow procedure in paragraph 115. Engine High Idle (WC-WF) 1575 rpm Engine High Idle (WD-WD45) 1720 rpm Engine Speed Loaded (WC-WF) ., 1300 rpm Engine Speed Loaded (WD-WD45) 1400 rpm 120. OVERHAUL. To remove governor weights unit, remove two nuts and cap screw which retain magneto or distributor bracket to engine and withdraw bracket and shaft gear and weights assembly as a single unit. The weights and trust bearing can be renewed at this time. If shaft, gear, or bushings require attention, the shaft should be removed by bumping out the drive pin (28— Fig. AC52G) on magneto equipped models or remove distributor unit drive gear on battery ignition models. When bumping out the pin, be sure to prevent bending of shaft by bucking up same with a length of pipe introduced through the opening in the bottom of the magneto drive bracket. On the WD, WC and WF gear (17) is sold only with the shaft assembled, not separately. To avoid damage to the shaft when removing the gear, cool the shaft while heating the gear. Shaft should have .002 running clearance in bushings. It will be necessary to remove the timing gear cover if the governor throttle shaft and cross shaft are to be overhauled. With cover removed, check cross shaft bushings and, if necessary, renew same. Check governor lever spring eye holes jind contact surfaces. Fig. AC52F--Models WC, WD. and WF engine governor iinicage installation. Engine speed adiustment is made at pomt (4) by increasing or decreasing iengtfi of rod (5) Goveiior linkage on WD and WD45 with battery ignition is similar. |
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 22 Oct 2010 at 9:16am |
i got a carb back from rebuilder and fired up and went wide open. He changed the throttle plate inside and linkage was backwards and I didn't catch it. Nothing like a new engine going sky high right away!! |
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
