wd governer
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: wd governer
    Posted: 08 Aug 2011 at 11:41pm
My 53 wd only goes to 1/2 to 3/4 throttle. Ive tryed adjusting the linkage between the hand lever and governer, but no results. The PO tied a piece of bailing twine to the governer lever that goes to the carb. The governer works fine when you add a load to it, but still doesent get past 1/2 to 3/4 throttle. Should I shorten the rod between the carb and governer? I have a tractor pull this weekend and have a rebuild kit for the carb. Could it be a carb problem?
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 2:31am
After going through the IT manual, Im going to pull apart the governer assemboly. I suspect the problem is in the governer housing. Anyone else have this problem?
Thanks
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 9:07am
IS this while just sitting?  If so, that is corect, it should only go about 1/2.  When under a load, the governer will push the throttle to wide open to keep the rpms in range.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 9:11am
Put a 170 governor spring in it.that will pep it up.
I couldn't repair your brakes, so I made your horn louder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 11:24am
Its while traveling down the road.
Andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 2:17pm
Does the throttle lever go to full throttle if it doesnt its the rod going up to the bell crank that pulls the horizontal rod going to the gov.
