wd Govenor??
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Topic: wd Govenor??
    Posted: 30 Sep 2023 at 7:06pm
I got my wd running today, it hadn't ran in 6 years. Anyway my question is on the throttle/Govenor. The throttle lever will only pull about half way down. You can force it more but it just returns to half throttle. I unhooked the linkage to the govenor and it is obviously the issue. The arm will only move roughly a 1/2" before springing back. Just looking for help before I tear into it. Thanks.
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2023 at 8:03pm
Broken counterbalance spring above the right headlite. Probably not even there anymore.
Post Options Post Options   Thanks (1) Thanks(1)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 4:11pm
You nailed it. Thanks Doc. I can't believe it was that simple.
This page was generated in 0.099 seconds.
