WD generator overcharging & tire replacement help
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 2:15pm
Maybe the 7 gallons of fuel escaped from the same hole that it went into?
Newwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newwood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 4:43pm
Sparky: Well, my first thought was someone had liberated my fuel, but my top candidate is slow ooze around the stem of the shutoff valve.  It's not enough to even form a drop, but it is enough to be wet to the touch just after drying with a towel (but it's been fine in years past).  So I tightened the stem nut and will hope for the best when I return (but I'll try not to leave that much gas in it next time!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 7:23pm
Adjusting the packing nut usually fixes the problem let’s hope so. Good luck.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 9:39am
Originally posted by Newwood Newwood wrote:
Just a followup note to anyone who likes to read to the bitter end...
Yes, I do like to read to the bitter end and thank you for the update; so often we never do hear how things turned out Smile
This page was generated in 0.039 seconds.
