WD front end-loose steering
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: WD front end-loose steering
    Posted: 24 Sep 2010 at 11:43am
I have about a 1/2 turn of the steering wheel loose on my WD. I do have it narrowed down on where it is starting from. The universal joint is OK, and I took the front inspection plate off the front end, and the worm gear looks fine with no major slop. I have it down to the lower end on my narrow front.
What can I expect when I remove both tires and take the spindle off? Is this a keyway and key type connection?
Thanks! Don
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 12:56pm
There is a large keyway on the bottom and there is a big setscrew on the back side to tighten things up. YOu might try tightening that set screw first to see if that helps.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
This page was generated in 1.516 seconds.
