Wd flywheel
dougsiefert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dougsiefert Quote  Post ReplyReply Direct Link To This Post Topic: Wd flywheel
    Posted: 16 Oct 2016 at 7:35am
I'm putting my WD back together after replacing the ring gear on the flywheel. The flywheel seems to only want to line up on the crank in a certain position, Is this the right spot or do I need to find tdc. and line up the timing mark like my book says. I'm afraid that I might install it 180 out. Any advice.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 8:21am
It only goes on one way...can't mess that up!   Rick
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 7:05am
Just installed mine last night too! Only goes on one way. Good job Allis engineers
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 8:59am
Before removing the WD flywheels paint one of the bolt holes on the flywheel and crankshaft and then install two studs in the crankshaft for alignment makes installing that heavy flywheel a lot faster, no turning the flywheel around on the shaft.
This page was generated in 0.152 seconds.
