WD final drive lube |
DanC911
Topic: WD final drive lubePosted: 29 Jan 2017 at 9:04pm |
I was looking in the manual for the final drive lube for my WD and it says SAE 140 above 32 degrees and SAE 90 below. Looking online I get a lot of hits for 85W140. Is this acceptable to cover the temp swings here in southern New England? Any suggestions are appreciated.
Jim Hancock
Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Thanks(1)
Posted: 29 Jan 2017 at 9:07pm |
yes.
How blessed we are by HIS GRACE!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8737 |
Thanks(1)
Posted: 29 Jan 2017 at 9:12pm |
yes,mines had 80-90 in Illinois for 37 yrs
DougS
Thanks(1)
Posted: 29 Jan 2017 at 9:32pm |
Just as engine oil has improved greatly, so has diff lube. In fact, lower viscosity lube will rob less power.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1526 |
Posted: 29 Jan 2017 at 11:22pm |
Just going thru that now - you can see post below. I will refill with 80-90.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 30 Jan 2017 at 2:47pm |
In fact, when the B's came through in the 40's they came through with 140 in the transmission and final drive. It was a pain getting it out when we put PTO and Hydrallic on. Had to use Kerosene to clean out the old oil or else it would give the hydrallic a problem.
I believe all units sold in the 40's had 140 lub in the final drives. Good Luck! Bill Long |
MACK
Posted: 30 Jan 2017 at 10:19pm |
Hydraulic wet brake or universal hydraulic oil. MACK
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 31 Jan 2017 at 8:07pm |
Mack, universal hyd......oil or fluid? What's the difference?
MACK
Posted: 01 Feb 2017 at 7:22pm |
Same, some call it one and another call it different. IH call it HI-tran, Ago call it 821, JD call it 303 or maybe some thing else
today. MACK
