WD engine |
Craig (KY) ![]() Bronze Level ![]() Joined: 18 Jan 2011 Location: Kentucky Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Jan 2011 at 6:02pm |
I thought I read on here that one could put a WD-45 crank and sleeve/piston set into a WD engine. If this is possible, is there anything else required. Thanks!
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Not really. It would be benificial to use the WD45 head, carb, and air cleaner. Head is probably a wash, but the carb/air cleaner were bigger on the WD45.Thats what I've done to my WD. 45 crank, head, carb, air cleaner on a 4" AGCO overhaul kit. Someone else will have to chime in about the manifold. I know the aftermarket ones are for a WD-D17, but I'm not sure how one would compaire to an original WD for carb flow.
AaronSEIA
daveingreenbay ![]() Silver Level ![]() ![]() Joined: 09 Oct 2009 Location: Green Bay Points: 277 |
Put a `45 crank, 4 1/8 sleeves and pistons in a `48 WD block. Used the original head, air cleaner and carb. Had all the rotating assemblies balanced. It dyno`s at 45 HP. You can`t tell externally that anything is different until you plow with it at half throttle.
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Better put a 45/D17 carb and manifold on if you want best results.Dad put M&W's (for a WD)in the WD in 62 and was sadly dissapointed with the upgrade untill he installed a 45 manifold and carb.It would work right with any stock 45 after that and is still running today.
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Is there enough "rotating" clearance on a WD-WC block for the 4.5" crank? I thought that is why the Dash 40 block was so sought after is because it was wider to accept the larger crankshaft from the WD45?
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
It will fit but what is a Dash 40 block.
Wink I am a Russian Bot |
the dash 40 block was the last version of the Wd motors with the side plate. if you read the AM number on the right side it will end with a
-40. From what I have learned they are sought after by the pullers because they have a larger bottom end for the larger rotating assembly that the wd45 crank requires? I know they physically look larger (wider)where they meet the bellhousing. |
Learned something new again. The crank will still fit in any 201 block as far as I know. They might be after that particular block because a stroked crank will fit without as much grinding. That's my thoughts. I have put in and taken out 45 cranks in WD and WC blocks before and never paid any attention to the block casting number.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21988 |
There is a little more room for a bigger than 4 1/2" crank, but the main reason is the -40 block is stronger above the center main saddle. All older blocks are open in that area and the -40 is all cast iron. In short, a stock stroke WD45 crank will fit with no issues in all WC-WD blocks.
